Why does AT prefer (1280x800) display over (1366x768).?
lxskllr
60,523
10,897
16:10 is better cause you get widescreen with more vertical pixels. It's a good compromise between 16:9 and 4:3
Ichinisan
28,298
1,235
16:9 is fucking awful for computer work. It's just sad that display manufacturers want to save money by using the same panels they already use for television displays.
Even 16:10 isn't optimal for reading and working. I have to put my taskbar on the left side of the screen to make it just a little bit more tolerable. Even that little bit helps a *lot* - seriously.
27.5" viewable 1920x1200 16:10 here.
Ichinisan
28,298
1,235
Real computer work needs more then 1 screen anyways.
2x 16:9 displays is almost worse than 1. It's like being extra, extra, extra wide. I have to do that at work.
I do make full use of it though. Glad Win7 and Win8 work OK with the taskbar on the left side. I also use my AeroSnap keyboard shortcuts a lot ([WinKey]+[ArrowKeys]).
SKORPI0
18,500
2,426
Obsolete displays, I've been using 2560x1440 2 1/2 years ago. :hmm:
13,917
4:3 was still the best ratio for computers, too bad that's pretty much dead now.
A monitor that would be like 8000x6000 would be awesome. Resolutions have pretty much stagnated.
Would also be nice if operating systems had better multi monitor support. Linux completely blows at it, and even in Windows it can get flaky with 4 or more screens.
CoPhotoGuy
452
Depends on what you do. For photography, 4:3 monitors aren't the best.
Ruptga
10,246
207
What is superior about (1280x800) display ?
They're both shit, unless we're talking about a five inch smartphone. Anything less than 1680x1050 is junk that should have been discontinued years ago. My desktop is 1920x1080, hardly impressive anymore but it's good enough to use more than one document/window at a time. I also have a crap laptop and I hate having to work on its 1366x display.
Carson Dyle
8,173
524
What I dislike about many wide screen monitors is the lack of height, both in pixels and in their physical size, either of which would be a step backward for me. I'm still using three 19" 1280x1024 5:4 monitors. As far as desk space is concerned, I could fit a widescreen in the middle, but then the alignment wouldn't be quite right. And three widescreens of the same resolution would too much for my desk. I think I might go to 6 x 1280x1024 some day, with a second row above the current one. I could probably pick up another three of the same monitor I have now for under $200.
IEC
14,605
6,093
Neither, both are poop for serious work. Not enough vertical pixels.
n7
21,281
4
16:9 is garbage, and vertical pixel height DOES matter.
768 = ancient CRT resolution from decades ago.
ElFenix
102,404
8,575
2560x1440 is the first 16:9 resolution that is work useful. when i moved from 19" CRTs to 20" LCDs i went from 1600x1200 to 1680x1050 and was constantly missing the vertical pixels.
i don't know how anyone uses the smaller ultrawide screens. like looking through a gun slit.
