why does AIM keep disconnecting?
Sniper82
16,517
It keeps disconnecting and reconnecting every 20-30 mins or less. Got a Netgear router(wired).
EvanB
268
I don't know, but I would suggest trying gaim. Gaim.sourceforge.net. Open source version of aim that is compatible with msn yahoo and others if you want that. But the main reason Id try it is to see if it has the same problems. You may find you like it better anyway :)
delroy
240
gaim, or trillian, or miranda all good clients
i would actually switch back to gaim if there was a non linux based "word swap" plugin
FlasHBurN
1,349
Hey, I have that exact same problem. I also have a Netgear router.
Rottie
4,795
Time to dump Netgear router and get yourself with Linksys or Dlink routers. So few people buy netgear these day.
My Trillian Pro 3.1 and AIM client works fine with my Linksys router.
Sniper82
16,517
From what I heard CS:S has problems with Linksys. Or at least the older ones. Reason for me buying this wireless Netgear is I got it for $12 shipped with no rebates and it has seemed to fix the CS:S issues. I am sure it's something simple somewhere.
BW86
13,114
30
I'm using AIM with ad hack and I've had it up for a couple of days now.
