Why do TV's and set top boxes sometimes go unresponsive until you unplug them from the wall?
futurefields
6,470
32
I've had several TV's that sometimes, seems like every few weeks or so, like the remote control will stop responding, or it will just become really laggy. It happens with my blu ray player sometimes as well. Only fix seems to be to unplug the unit from the wall and replug it.
What phenomenon causes this to happen with consumer electronics?
SKORPI0
18,481
2,418
You'll have to spit on it to make it more responsive. ;)o_O
Devices are on "sleep mode".
Thebobo
18,574
7,672
If you waited until the time it took for you to get up and unplug your device plug it back in and then try it again it would've worked if you just waited.
disappoint
10,132
382
I've only had that happen to a Vizio TV I have. Most likely the program crashed and the system needs to be reset. They should come with a reset button. You can rig your own reset button if it bothers you often enough, you're handy with electronics and it's out of warranty. Just run the main power supply through a normally closed push button. Make sure the button can handle the current and voltage that the power supply draws.
13,801
computerization
It's actually funny, since computers are suppose to make things better, but some things should simply not be computerized. TVs are one of them. Why is it that a TV now actually has a boot up time. Back in the old days of tube TVs you turn it on, and it turns on. Yeah it took a few seconds for the tube itself to warm up, but you got sound and responsiveness to any input right away. But now, my TV has to do this little jingle at the beginning and takes a good 10sec just to boot up. In some ways it seems we went backwards. lol.
disappoint
10,132
382
I have an LG 55" 4K set that turns on instantly. The smaller Vizio takes a few seconds, then the remote is unresponsive for a few more seconds, then it's usable. That's if it turns on at all without being reset. Some manufacturers just suck.
Kaido
Feb 14, 2004
51,478
7,221
I put Tech Restarters on everything. $22 each, big easy-to-set timer, and two 3-prong outlets per unit:
https://www.amazon.com/Tech-Restarter-Digital-Outlet-Timer/dp/B01C66X6GU/
I have them reset the following items every night:
1. Cable modem
2. Wireless router
3. Wireless repeater
4. Arlo camera hub
5. Wink smart home hub
6. Roku television(s)
Everything is set to restart at 3am, when I'm asleep. Keeps things working smoothly. Wish I knew about these years ago!
Reactions: angminas
13,801
Haha my hospital could have used that for their IVR. Every freaking night that thing would crap out. It consisted of a phone wired into a desktop sound card and some super custom software supported by some 3rd party outsourcer. I died laughing when I saw that setup, it looked like a 1st grade science fair project. We could have done something better, but organizations always insist on outsourcing this kind of stuff, and that's what they get.
Thebobo
18,574
7,672
1. Cable modem
2. Wireless router
4. Arlo camera hub
Interesting, not sure these days but long ago a lot of electronics most stressful times is when they power on. So you could be shortening the life of your device if you believe that sort of thing.
Kaido
Feb 14, 2004
51,478
7,221
I'm okay with that...I would rather have them work smoothly for a shorter time than be glitchy over a longer period of time. Also, haven't had any issues so far, but time will tell!
WHAMPOM
7,628
183
The manufacturers were too cheap to wire in a reset button.
Charmonium
10,527
3,526
It's easier than that. Just get a switchable outlet. Basically it's something that plugs into your wall socket or UPS and has a built in switch. Some are lighted so you can tell if they're on or off.
Use one of those with your device. when it starts acting up, just flip the switch, wait about 10-15 seconds, and switch it back on.
ImpulsE69
14,946
1,077
Hmm...never had this issue. OP needs to read a manual or learn to work a remote :)
13,801
as soon as they build the firmware to the point where it looks like it works, it ships. then they never touch it again.
Pretty much. I find that goes for a lot of things that have software, the software is always a quick after thought that has to be rushed (and probably is outsourced). Even drivers. You buy this super high end video card, and keep getting system crashes or other issues and a good part of the time it's driver related. The hardware will be fine but the drivers will be buggy.
Reactions: disappoint
bigboxes
42,212
12,415
My Fire TV has to be power cycled now and then. The supplied remote (WiFi) needs to have the batteries pulled on occasion when it becomes unresponsive.
