H Herr Kutz Platinum Member Jun 14, 2009 2,545 242 106 Oct 8, 2018 #1 Is it kind of like how a sandwich made by someone else tastes better?
paperfist Diamond Member Nov 30, 2000 6,539 287 126 www.the-teh.com Oct 8, 2018 #2 They absorb more moisture from the air when they are sliced. Reactions: Perknose
dabuddha Lifer Apr 10, 2000 19,579 17 81 Oct 9, 2018 #4 They're bathed with the tears of the sliced almond
ch33zw1z Lifer Nov 4, 2004 39,816 20,423 146 Oct 10, 2018 #5 Are they raw or roasted? That's the big difference, then there's the whole salt / no salt thing.
zinfamous No Lifer Jul 12, 2006 111,914 31,440 146 Oct 10, 2018 #8 Mayne said: I need some almonds now. Click to expand... does that help alleviate the maynestruation pains?
purbeast0 No Lifer Sep 13, 2001 53,683 6,564 126 Oct 10, 2018 #9 I'm just here to let you all know that these are the best almonds in the world.
KB Diamond Member Nov 8, 1999 5,406 389 126 Oct 11, 2018 #10 More tongue contact with the center of the almond instead of the skin which dries out. Just like why sliced cheese is better than cubed. Reactions: Herr Kutz
