- Aug 20, 2005
- 2,685
- 11
- 81
I had a Droid Incredible and now have a Galaxy Nexus. With both phones, the phone gradually became slower and slower over time, even after a reset. (Don't get me wrong, it's always faster after a reset, but not as fast as it was new, or even after the previous reset) Now I know the counter to this, in most cases is/are any of the following:
-Did you update the software? (ie go from 4.3 to 4.4)
-Did you have a ton of apps installed? (widgets, background processes, etc)
-Physical damage to the device?
And I tried to counter these by keeping a consistent number/selection of apps installed on the phone and almost always factory reset then tested the responsiveness before updating to a new/different Android version.
At one point in time, I cracked the screen on my GNex and got it replaced. Before getting it replaced, I reset to factory and noted the responsiveness (keeping an eye on the apps that were installed/re-installed). I then sent the phone back (headset insurance) and noted the speed (it was the same android version). It was noticeably faster after configuring and installing apps to parity with the old phone.
Is it a hardware degradation issue? If so, which parts would be breaking down?? I've reset this GNex 3 times now... and at this point, there are pauses of up to 5 seconds between screen transitions, ie while waiting for apps to transition or just going from texts to the home screen. On my PC, a fresh windows install gets it back to like-new. I don't get it...
I'm looking to get a new phone soon and am looking at only the fastest devices because I know this'll probably happen again when that device is 1-2+ years old too. It's just frustrating and I want to understand.
