I have an Asus V7700 64MB GeForce 2 GTS which I have set at 200/400. I'm using coolbits and I have it set to apply settings at startup. But it keeps taking my settings back to the default 200/333 when I reboot.
i think this worked for me, set up ur settings u want, test it, then hit apply(not apply at startup), and then ok. close it, then open it all up again, and select apply at startup. then ok
Since Coolbits is a reg hack (so to speak...) it sounds like the registry is not saving the config upon a reboot??? Might be related to OC`ing (if you are???). If so try it at stock speed... Also could be a glitch in the Coolbits program???
