Why do my Logitech Z-560's make a popping crackling sound when I turn up or down the volume?
roncarter
1,935
This usually only happens when I havent touched the volume settings for a while. After the first crackling or popping sound, I can turn up or down the volume and it doesnt do it anymore. Then after a couple hours of not using it, it happens again. Anything I can do to fix this annoying problem? or is it a defect in the speakers
amdskip
22,530
13
I'm pretty sure it's a defect in the speakers. How long have you had them? Do a search of the forums and you will find many other people reporting the same thing.
lenjack
2,706
7
I think it is a problem with the volume control. The contacts get dirt or dust in them and become intermittent. I usually solve this by spraying contact cleaner, made specifically for this purpose, into the volume control, . But if you're in warrantee, call Logitech.
stevewm
742
This is typically a sign that the volume control is dirty.
There is a easy easy to clean it without chemicals though.
Turn the dial very quickly back and forth through its entire range of movement. The quicker the better. Just a few seconds of this will clean it up and should stop the popping.
roncarter
1,935
cool.. ima try this. im not at home right now but ill let you guys know if it works or not
lenjack
2,706
7
Sometimes this is a temporary fix. If the noise keeps comimg back, you'll need to spray.
roncarter
1,935
whats this spraying contact cleaner your talking about?
OverVolt
14,278
89
I have those speakers, haven;t hooked them up yet.
I'll let ya know if they crackle when i change the volume.
lenjack
2,706
7
RadioShack and other electronic stores have it under different names.
I've seen it called tuner cleaner or degreaser. Don't get one that contains lubricant.
