Originally posted by: Oscar1613
if they did broadcast on even frequencies, would you still be asking this question (in reverse)?
Originally posted by: trmiv
In Europe it's even numbers, right?
Originally posted by: beer
Every realizable signal is time limited, therefore it has infinite bandwidth. All communications signals exist on all frequencies, but they are greatly, greatly attenuated depending on the design of the transmitter. Therefore, it comes down to filter design to attenuate the signal at the appropriate frequencies. I believe that with FM in the US, the FCC defines 200 KHz of bandwidth for each station, but the bandwidth is not 'true' bandwidth (which is infinite) but '99% signal power bandwidth', that is to say, the integral of the frequency response curve centered at X MHz, symmetric about each side with integral bounds of 100 KHz +/- the centered frequency would be 99% of the true infinite bandwidth of the signal. Therefore, if you tuned into 90.0 MHz, you would be halfway in the signal spectrum of 89.9 and 90.1, which would be garbage to a human ear.
Originally posted by: Stefan
Why do major radio stations broadcast on odd frequencies like XX(X).[1,3,5,7,9] and not [0, 2,4,6,8]?
i don't think so, but it wouldn't surprise me if they were even in freaking canada...
Originally posted by: So
This is basically correct. :beer:
I am not exactly sure if the FCC uses '99% power' bandwidth. A quick reference to the Sklar text leads me to believe it might be 35 dB attentuation bandwidth. I'm not sure which, but for all intents and purposes I think it's close enough
And these FCC regulations were made a long time ago anyway. It is very easy to lock onto an FM signal using phase-locked loops or even varactor diodes, so if the standards were rewritten now, the bandwidth rolloffs wouild be more tightly defined. But back in the 30s and 40s, such technologies did not exist, and it doesn't make sense to change anything now due to all the grandfathering requirements of changing communications standards.
Originally posted by: Syringer
How come there's no channel 1?
This is correct except for the fact that analog radio is probably lowpassed to 40 KHz or less before even being modulated so the "infinite bandwidth" part is purely theoretical.
As a side note to non-engineers, the modulation scheme makes a big difference in the necessary bandwidth. A simple AM modulated signal in a perfect environment would, in theory only need about 45 KHz bandwidth for "CD-quality" sound.
Come on, speaking of theoretical, there can be no ideal filter that gives 100% attentuation anyways. So yes, the 'theoretical' aspect of infinite bandwidth is there, but so is your ideal LP filter that smooths off exactly at 45 KHz. It doesn't exist. And for what it's worth, you should know that the modulation scheme has nothing to do with the receiver architecture. Signals are modulated onto a certain carrier wave because of the channel's properties. The FCC used the frequency range of 87-108 MHz because it has a fairly direct line of sight, and nothing else. It allowed them to densly pack FM transmitters, instead of AM transmitters that at night can interfere hundreds of miles away due to ionosphere reflection.
