Originally posted by: slugg
but see something i dont understand...
"Does <program> run on Mac?"
"Yes, under Bootcamp."
^^ well then you're not running it on Mac, are you? You just happen to be on Apple hardware, but if you're running Windows, you're on "any old PC." Alternatively,
"Yes, using Parallels."
^^ then you _ARE_ running it on Mac...
Another thing I don't understand is why Apple users expect anything _other_ than their Windows software working in Windows. Example:
"Does Halo 2 work in Parallels?"
"No, but it works great in Bootcamp! Macs rule!"
^^ What did you expect? OF COURSE it runs in Windows. This is nothing special. Now I don't know if Halo 2 actually works in Parallels or not, but it's just an example. So in this case, Halo 2 would NOT work on Mac. Due to the fact that you have to be running Windows to run Halo 2, it's not running on Mac; it's running on a normal PC with Windows. Yes it's Apple hardware, but _NOW_ with Intel in the mix, the only major difference between traditional PC's (factory shipped with Windows) and Apples is the operating system. You could get into little differences like EFI versus BIOS, but that's such a minute thing that it doesn't really matter. So if you switch the operating system to Windows, aren't you NOT running "Mac OS" anymore?
Personally, I'd rather stay on Mac OS. Why else would you buy Apple hardware other than to run OS X, ya know? Granted, I do understand that Bootcamp gives you the opportunity to run Windows as an alternative when needed, so this isn't really an argument, just a remark. If I had a bunch of Windows software that I needed to run, I wouldn't use a Mac for that purpose. Sounds to me like there are a lot of PC users that caved in to Apple's marketing. Again, I'm not bashing Apple here (I'm on you guys' side here; I _want_ a Mac badly. Money sucks
