Don't confuse "b" and "B". "B" = byte = 8 bits. Typical wireless can do 15-22 Mb/s max, which is much higher than typical home internet, so should not in itself be a bottleneck with a good connection, etc. You'd need to run diagnostics to see the actual local speed of your wireless connection.
E.g. using iperf 1.7:
server: iperf -s
client: iperf -c
server -l 64k -t 12 -i 3 -r
Here are some of my sample results:
F:\tools\bench\iperf>iperf -c 192.168.0.144 -l 64k -t 12 -i 3 -r
Server listening on TCP port 5001
TCP window size: 8.00 KByte (default)
Client connecting to 192.168.0.144, TCP port 5001
[812] local 192.168.0.141 port 31062 connected with 192.168.0.144 port 5001
[ ID] Interval Transfer Bandwidth
[812] 0.0- 3.0 sec 5.00 MBytes 14.0 Mbits/sec
[812] 3.0- 6.0 sec 6.06 MBytes 17.0 Mbits/sec
[812] 6.0- 9.0 sec 6.06 MBytes 17.0 Mbits/sec
[812] 9.0-12.0 sec 6.06 MBytes 17.0 Mbits/sec
[812] 0.0-12.1 sec 23.3 MBytes 16.1 Mbits/sec
[788] local 192.168.0.141 port 5001 connected with 192.168.0.144 port 1732
[788] 0.0- 3.0 sec 5.88 MBytes 16.4 Mbits/sec
[788] 3.0- 6.0 sec 5.75 MBytes 16.1 Mbits/sec
[788] 6.0- 9.0 sec 5.87 MBytes 16.4 Mbits/sec
[788] 9.0-12.0 sec 5.69 MBytes 15.9 Mbits/sec
[788] 0.0-12.1 sec 23.3 MBytes 16.2 Mbits/sec
This is across a wireless 802.11g bridge; short to moderate distance; a couple of obstructions... a pretty good result for the equipment and environment.
I can remote desktop from a wired connection into a computer which is connected using this wireless 802.11g; run a web benchmark going back through the wireless bridge to the internet, and get essentially the same internet benchmark as I get using a wired connection to the internet. In my case, the service is stated 5 Mb/s, and effective around 4.3 Mb/s max using those benchmarks.
In fact, at this time, the fastest benchmark result I've gotten was through the wireless bridge in this manner. But this just shows that such benchmark results can vary significantly due to external factors, so I'll just say that the speeds are essentially the same, not that my wireless is faster than wired for internet benchmarks.
There are some tweak that can be used to improve wireless Internet results (before Vista, which does such tuning automatically). E.g. TCPWindowSize and TCP1323Opts as in the following guide:
http://www.speedguide.net/read_articles.php?id=157
A reboot is required for such settings to take effect.
