Originally posted by: TKE899
Is the set 120hz?
Are you running HDMI?
Is the connection run directly to the TV or through a receiver?
There are a few things that could induce lag in the audio. The first thing I would do however would be unplug the cable box for a few minutes and let it reboot.
Are you splitting the cables cable?
Does your receiver have a lip sync / time delay adjustment?
Originally posted by: YOyoYOhowsDAjello
It's fairly common for people running with a receiver based system. I assumed you were using one. What's the model of the TV?
It could be the cable company DVR. There are quite a few models out that have poor firmware and can lose lip sync.
Menu - select audio - select lip sync - adjust
(pages 40, 41 of your manual)
This should give you the ability to try to correct the issue through the TV. I don't know where the issue is originating, but you may be able to fix it with this.
You seem like a person that LOVES manuals. DON"T YOU, admit it.
