Originally posted by: Specop 007
Is it because when I put the car in reverse the exhaust gasses go backwards too?
There's actually a built in electric motor which pushes your car backwards. Normal engines can't turn the opposite direction to turn the wheels backwards. Therefore, you need an electric turbo if you want to hear it. This will also give you 300 RWHP. That's Reverse-Wheel-Horsepower
Arent reverse and first gear the same thing, just that reverse makes the engine go backwards so you can drive backwards? I figured thats why I couldnt hear my turbo. Since the turbo only would work with gasses going one way, if the engine went backwards so that the exhaust gasses went backwards then the turbo wouldnt work.
Isnt that a good theory? Or am I off base a little bit here?
