Why are there so many HSFs and cooling articles about Athlons?
brucehao
162
I'm pretty new to building computers, but I find it kind of strange that there are so many HSF's and articles about HSF's for Athlon mobos. That is relative to 478's. Is there a reason for this?
Jacl
Yes. Athlons run at considerably higher temperatures than the pentium processors. I've heard it said that even a modest overclocker can get away with using the stock pentium hs/f. The reason that there are so many athlon coolers out there is that, when running at those higher temperatures, necessary cooling depends on many more factors than a pentium based computer. That is to say, with a minimal configuration and a decent case, you are safe using the stock hsf as long as you run things at stock speed and have relatively good cooling in your case. For overclocking of any sort, an upgraded cooler is a must. All the same, you would do good to look into getting a better cooler than the stock supplied just for the sake of keeping your processor in good condition. As a rule, your processor temps on an Athlon should never exceed 50C and the lower you can get them the better, depending on your needs of course. One more thing, case cooling complements a good hsf. If your case does not have good airflow, spending money on a really good hsf is not going to do you as much justice as it's capable of.
syberscott
372
At stock speeds Athlons do run hotter than Pentiums. However, when both are overclocked their temperatures even out in comparison.
OulOat
5,769
Most pentiums sold are to OEMs, which sells their comps to people who don't care about the innards of their comps. However, the majority of people who build their comps get Athlons, since they offer more performance for the buck. Thus, more hsfs for AMDs. Also, the stock hsfs for Pentiums is quite good itself, quiet and powerful. The stock cooler for Athlons, on the other hand, is a pretty much a POS.
I think 50C is too low to set a max barrier, since it's still far from the burning point of an Athlon. I would say stay away from 70 Cs.
Afro000Dude
746
Actually, even overclocked p4's are cooler than Athlons. My 1.6a @ 2.4 never breaks 40C at full load using the stock cooler.
Bookie
172
The real reason for this is that the people who actually care about the products in their system use Athlons. The majority of the users in this forum are Athlon users.
touchmyichi
1,774
Most people use the stock intel fan anyways, since it does a fine job and intel's run pretty cool anyways. AMD's are really hot, so you have to put some ice on fire. So thats why there's a huge market for AMD fans
OulOat
5,769
Lol. Let me guess, you are an Intel fanboy.
Jeff7
41,596
20
Yeah, really. I think the reason that Athlons are so popular is because they tend to offer more performance for the price. It can just be more fun trying to squeeze out every last bit of performance from the "underdog" I guess. And the heat production issue - actually, P4's and Athlons are fairly close in terms of thermal emission. The P4's just handle thermal disaster a lot better - the P4 itself will slow itself down considerably if the heatsink falls off; the Athlon XP requires motherboard support to shut itself off. Otherwise, it just fries.
syberscott
372
Thank you Jeff; finally someone has agreed with my position on heat output. Reading temps off different motherboards is useless in comparing differences between Athlons and Pentiums. The only way to compare them is to use a thermal probe in the same heatsink on 2 different systems. Posting individual results proves nothing.:)
arcenite
10,660
7
My guess is it's because Athlons for the most part run a little warmer (or alot depending on what chip) than P4's.
Bill
Doggiedog
12,780
LOL. The minimum my Athlon XP1700 would go was 50c. Near the end of it's life it was going around mid 60s.
After doing an autopsy, I found out why. I bought a preassembled MB combo and they didn't take off the thermal pad and it melted through leaving practically no contact.
OulOat
5,769
Eh? XP1700 isn't that old, how long did your chip last?
Confused
14,166
Most P4's are bought Retail, and include a good, and reasonably quiet, HSF.
Most AMDs are bought OEM, which come without a HSF, and even those bought retail, most agree that the HSF is only just adequate.
Therefore, there is more of a market for AMD Heatsinks.
Of course there are some aftermarket S478 Heatsinks, but with such a good retail cooler, there just isn't really the need for too many models.
Confused
Zap
22,377
7
Confused, you choose the wrong name, hehe. I've also noticed that Intel chips are more often retail boxed (with HSF) than AMD, and yes the AMD boxed HSF is on the weak side.
I think the general consensus is that AMD chips run hotter MHz for MHz, and I'd agree with it. Look at the spec sheets to see how many watts need to be dissipated. Plus, the contact area is smaller making for less efficient heat transfer (as I recall, if you take off the heatspreader on a P4 the core underneath is still bigger than Athlon cores).
Doggiedog
12,780
I think about a year. Not sure. But it wasn't the chip's fault really. It burnt out because of the thermal pad melting away. If I had known, I would have added some AS3 to it earlier.
