Why are the LED lights on my fans not working
pp_hurtz
I have had this pc for like two weeks and the fan LED's were working fine but all of a sudden when i get home and turn on my pc the LED's don't work but the fans are still on
aigomorla
21,034
3,513
possible the LED's blew out.
Try them on another header port to rule out bad header.
mindless1
8,679
1,721
What make/model of fans? Are the LED electrical contacts exposed or at least accessible so you can use a multimeter to check the circuit? Do you have a multimeter?
Is the fan on a fan controller or motherboard controlled header that varies the speed? The LEDs are "probably" in series with a resistor and a voltage too low could cause them not to light up at all, not just be dimmer similar to how the fans might get slower with a lower (average if PWM) voltage. Then again I expect you would have noticed that on a new build, before two weeks passed.
