Why are the environmentalists against nuclear energy?
quentinterintino
375
Wow, so much misinformation here!
First, reprocessing still produces waste. You extract some of the Pu in a PUREX process, but the other actinides are all in a waste stream.
Second, most of the heat load comes from Cesium and Strontium, which does dissapate after several half lives (hundreds of years)
Third, the long term heat load is caused by the "major" tranuranics - Np, Pu, Am, Cm... these won't decay for tens of THOUSANDS of years
Fourth, a coal plant does produce some radioactive flyash - but not nearly as much radioactive waste (measured either by activity or quantity) as a commercial nuclear power plant.
Fifth, in order for us to reduce our waste, we need fast spectrum breeder reactors to transmute the fuel. This will eliminate the need to mine for new uranium (it 'produces' it's own fuel) and it can change the nasty transuranics listed in 4) to other shorter-lived isotopes.
I can go on but I've got stuff to do.
Savij
4,233
Originally posted by: dug777
Long term strorage issues.
The potentially massive impact of a mistake/attack (sure it's incredibly unlikely, but the potential dangers posed are awesome, look at Chernobyl)
Those are the main two, and they're both extremely valid points that can't be ignored in a sensible debate.
Then there's NIMBYISM, to which i suspect many of you would subscribe, even tho you're so blase and keen online about nuclear power...
Read about the problems and causes of the Chernobyl accident.
Ryan
27,519
Originally posted by: ElFenix
Originally posted by: freegeeks
I vote for the socialist party in Belgium. For American standards I'm a communist, in Belgium I'm a "liberal" :p
i'm still trying to figure out how the word liberal became so twisted. for some reason has become synonymous with the all-powerful, all-knowing, health & safety nanny-state.
Because it usually stands contradictory to many fundamental American principles - the rife individualism that is at the core of western culture.
Amused
56,464
16,064
Originally posted by: chambersc
I am against it for nuclear waste. Fix that and call me.
I don't care how much energy it produces -- for me it's all offset by the potential for danger with the waste that is produced.
yes since all other ways to get energy are so much cleaner :roll:
Well, as long as it doesn't produce N-U-C-L-E-A-R W-A-S-T-E then it's definitely cleaner. I will forever be against nuclear technology for this reason.
Please provide a number on how many are killed in the US by nuclear waste each year.
Compare that to the tens of thousands killed each year by lung diseases caused by fossil fuel emissions.
Get a clue.
chambersc
6,247
its really sad. here you argue about something you really do not have a clue about.
Tell me how Nuclear power doesn't produce Nuclear waste. EVERY other minute aspect of Nuclear power I do not care about. The ONLY thing I care about with this technology is its negatives. Show me how the waste isn't bad or doesn't have the potential for bad and you'll convince me. Other than that concede defeat.
Get a clue.
Read me edit. I'm against Coal as well.
Ryan
27,519
The point is not the problems directly - but the fact that humans have the ability to err, and as long as we do, their is ALWAYS a possibility of an accident, no matter how small it may be. All of the failsafes in the world could be packed into a nuclear plant, but the possibility still exists.
quentinterintino
375
Get a clue.
I agree with you, but can you prove how many lung diseases are caused SPECIFICALLY by fossil fuel emissions rather than stochastic or extraneous effects ? ;)
Edit: spelling
dug777
24,778
4
I have, your point?
AMDZen
12,589
bs, I'm a liberal (if I was living in the USA you would probably label me as a communist).
nuclear energy is just common sense, and "liberal" countries like France and Belgium depend on it for 70% of their energy production
commies aren't liberal.
So you just explained the difference between Liberals in American and Liberals in Europe. Oh wait, not really - they're pretty much the same thing.
Its just unfortunate that Kids my age especially, take everything their college professor's say as gospel and don't bother doing any research of their own. And unfortunetely, they're (college professors) all singing the same tune around the country.
everman
11,288
Please, just stop mentioning Chernobyl as good reason for not wanting nuclear energy. It's not a credible argument, modern designs are very different and very safe.
AMDZen
12,589
Not to mention that Chernobyl wasn't safe even in its time. The russians cut so many corners, that they knew then they shouldn't have cut - its shocking. And the knowledge we've gained on nuclear power since that disaster is 10 fold.
Savij
4,233
I have, your point?
Find a single nuclear reactor based on that...what was the word positive coefficient system in the free world.
waggy
68,143
10
not to mention we put more money into them then the Russians did.
though IL had one closed because the people running it (think com ed) was not keeping it up. they found something like 22 major problems and forced them to close down. this was like 3 years ago or so.
dug777
24,778
4
You miss the point of using Chernobyl as an example. It's being used here to illustrate what COULD happen if stuff did go badly wrong, by an incredibly unlucky chance event, or more likely a terrorist attack, in terms of fallout range/effects/etc...
No one is saying it's likely, or that it will happen in the same way, but imagine a nuclear meltdown on mainland USA, with unfavourable winds that might carry fallout over ten states and potentially hundreds of millions of people?
It's not an argument in itself ;)
Kwaipie
1,326
We are moments away from our own Chernobyl. Check out how quickly waste is migrating towards the Columbia River courtesy of Hanford. We do not have the technology to safely transfer or store waste. Leave it to the conservatives to put today's problems onto future generations. I love that people want to put this stuff on a rocket and fire it at the sun. Someone is watching too much Johnny Bravo.
In an age of terrorism when we're only checking 5% of incoming cargo containers, you want to drive nuclear waste around the country? Sounds like a recipe for disaster to me.
Amused
56,464
16,064
http://en.wikipedia.org/wiki/Zion_Nuclear_Power_Station
This one?
quentinterintino
375
If you think that they transport HLW or SNF across the country un-checked....
Pantoot
1,764
30
Ignalina in Lithuania. (Although it is scheduled to shut down #2 in 2009.)
dullard
25,476
3,974
So you are against coal that produced 49.8% of energy in 2004. You are against nuclear that produced 19.6% of energy in 2004. What will replace them if we end nuclear and coal today? Oil? If we use 5 times the amount of oil that we currently use, what would happen to oil prices? How long will that last us? Is there even the capacity to provide that oil?
Kwaipie
1,326
Oh, I feel better now.
waggy
68,143
10
This one?
yeah i think so. ok so my time fram is a little off though hah!
dug777
24,778
4
Of course, a much easier option is to try using less power...
I would think that a nationwide program to educate people about using CFLs, turning devices off rather than using standby, bulding codes that reduce reliance on AC and heating, putting more emphasis and compulsory power usage ratings on equipment could have a dramatic influence on power requirements if done correctly and effectively ;)
EDIT: not that it will solve the problem of where the power comes from, i was just musing to myself :eek:
Amused
56,464
16,064
And the ignorance continues...
Meanwhile tens of thousands die each year from fossil fueled plant output.
Kwaipie
1,326
Oh, please teach me. Cure me of my ignorance. But please give me your home address so I can hire a hitman to take you out when Hanford dumps its load into my river.
I wish I was smart like you. While you're at it, how about something to backup your "tens of thousands" claim. Preferably a source that isn't Pro-nuke.
