Why are my stats kinda low?
SinfulWeeper
I just did a scan of all my computers after my camp work (going back out tommorrow 🙂), anyway here is thier production rate.
P4 2.53GHz @ 2.85GHz = 479,524 cEMs
P4 1.6GHz @ 2.048GHz = 404,127 cEMs
C4 2.0GHz @ 2.560GHz = 394,562 cEMs
C2 1.0GHz @ stock speed = 128,792 cEMs
Total their is 1,407,005 cEMs
Then their is my mothers part time cruncher which adds another 110,000 +/- cEMs. And a newly assimilated computer I did two days ago at a friends house, adds another 298,000 +/- cEMs.
I double checked the config on the clients, and all settings are correct. So why is my rate at a mere 1.3M? Shouldn't it regularly be over 1.5M like towards the end of last month?
All the computers are on broadband, so dial-up reasons to not contribute. Anyway I am a little 😕 right now...
The cEMs/sec rate varies depending on the k/n values. I can't remember which is fastest combo, but the numbers we are working on are changing, so this is why there will be the variation in speed.
Garry
I hope your correct, but I do not think you are.
The cEMs on the computer are averaged out for the duration of the time the client is running. However the client was remaining constant, except for the moments it was fetching a new block. About half way though the block it would return to where it was, more or less.
After I rebooted it still went to the same cEMs/sec with just a hair more speed behind them. So I thought to myself that the SoB stat page was screwy, so I turned off a client for a few hours (did a dusting job while @ it 🙂), and sure enough, it did see the drop in my rate. But it still does not even come close to what it should be...
Keeps on scratching my head while I think more about it.
<---Loves your new sig 😀
