- Aug 19, 2001
- 1,628
- 0
- 76
With the right promotions, you can find SSDs as low as $1/GB for a 64 GB SSD. So why is it that the lowest price we see on 96 GB SSDs is ~$120-150ish ~$1.2-1.5/GB? And similarly, why are 256 GB SSDs close to $2/GB?
It's not as though higher capacity SSDs use twice as many controllers. All that differs (in some designs) is that more NAND is wired to the same controller. Even if a manufacturer needs to run an internal RAID 0, the chipsets don't seem like they could be expensive enough to be responsible for the costly price increases. It seems to me that manufacturers just want higher margins on higher capacity drives. (Which they're welcome to do- I just won't be buying in at those margins.)
Is there some fundamental reason for why higher capacity SSDs should be disproportionately more expensive than their lower capacity siblings?
