Why are connection adapters even possible?
ShawnD1
This has been bugging me for a while. How is it possible to have an adapter change a parallel connection into a serial connection, or a ps2 connection into a USB connection? If it's possible to emulate a 25 pin parallel connection using only 9 pins (serial), why does the 25 pin connection even exist? Wouldn't that mean 16 of those pins do absolutely nothing?
Well, it depends.
Parallel uses more pins because data is sent in parallel over multiple pins at once. Adapters aren't just changing the pinout, they have some electronics to reformat the data a bit (edit: no pun intended). There are advantages to both serial and parallel transmission, thus the existence of multiple standards.
PS/2 and USB is a bit of a different case, but you should note that the USB device -> PS/2 port converters are specific to mice that are compatible with them (IOW, not all USB mice will work through such an adapter), but like the older P@/s -> serial adapters weren't compatible with absolutely all PS/2 mice. The converter does a little bit of voodoo to make everything work.
Different connection types often exist for historical reasons, and sometimes quirks of a standard are simply due to the limitations of contemporary equipment.
For an interesting case, look at VGA. 15 pins, sure, but 14 conductors in the cable. 1 is left out and used as a key to prevent the connection of the wrong type of device. 5 separate grounds, 4 pins reserved for Monitor ID, 2 sync signals. Of the 15 pins in the connector, 3 carry video data (red/green/blue). It is telling that DVI-I manages to safely compress all of this down to 5 pins: red, green, blue, sync, and 1 ground. But the extra pins in the original connector helped ensure better signal integrity, and at the time made perfect sense.
I guess someone decided the conversion was necessary and just did it. It's not really that hard if you think about it a bit. they have single chip conversion ICs with a memory buffer built in. Ser to Par, you just let the bits store up in the buffer until you have 8 or more and then send 8 out together - vice versa for Par to Ser.
.bh.
