Why is it necessary to put the master device on the end of the cable, and slave on the middle connector?  Since in most cases, the HDD cage is located at the bottom, this many times keeps you from putting a device as a slave on that controller since it will probably be located above the HDD cage and the cable probably won't reach back down to the HDD (master) after connecting to the slave device.  Especially true if you have a 3.5" external bay (floppy/zip) in between the two (like Antec cases).  And if it will reach, this makes you put the secondary device in the bottom external bay which you may not always want.
Or maybe they make ATA66/100 cables with longer distances between master and slave connector? If so, only the short ones ever come w/ the mobos I buy for some reason.
[/rant]
[/rant]
 Facebook
Facebook Twitter
Twitter
