why am i having trouble regulating my body temp?
stev0
5,132
Just recently started going back to the gym after a month long break, xmas break and all. now all of a sudden i can't keep my body temp constant, it can be 10F outside while i'm walking to class and i'll be sweating, or it's about 72F in my apt. right now and im freezing cold. wtf is going on?
PunDogg
4,529
cuz your body is repairing its self after working out, and when u work out your metoablism goes up therefore increasing your temp. Also depends on when you ate, if u just ate u will fill colder than if u hadn't ate in a while
DOgg
Corsairpro
2,543
outside you are moving briskly. in your apt, you aren't walking briskly, IE generating less body heat.
Yax
2,866
Use the right hand rule dude. Your right hand, choking the goose till it pukes will solve all your woes. ;)
stev0
5,132
DOgg
why would i feel colder after i eat?
KingNothing
7,141
DOgg
Blood rushes towards your stomach to help digest the meal. This is also why you feel tired after you eat a large meal.
stev0
5,132
Originally posted by: flxnimprtmscl
Try applying some new thermal grease. Might want to replace your fan too :p
dude... you really do need to get out more
:p
so this is normal? i've never really noticed it before and it's starting to become a pain in the ass.
TheBoyBlunder
5,742
You might want to check for dust clogging your system's fans. That can cause odd temperature fluctuations.
Siddhartha
12,497
How tall are you and how much do you weigh?
Do you have a fever?
stev0
5,132
5'9'' 200lbs
Jan 18, 2001
14,465
Three possibilities:
1) you are going to spontaniously combust soon
2) you are going through menopause
3) you have a thyroid problem. seek professional help.
ASK THE COMMUNITY
TRENDING THREADS
