KingFatty
Hi all,
I'd like to *reduce* the idle fan speed of my reference 5850 to less than 20%, to make less noise.
I don't mind allowing the card to run a little warmer and I'm fine making a custom profile to reduce the idle speed to say 8% when the temps are acceptable at idle.
However, are there any other hidden dangers? Example: would the fan mechanically suffer if run at a slower speed most of the time? Is the default 20% minimum done for any other mechanical benefits? I know with some gasoline engines it's suggested to run them a certain way, so maybe some of that is applicable to electrical motors/brushes/bearings? Are GPU engineers choosing the default idle fan speeds due to something besides GPU heat/performance, such as according to some hidden specs for the electrical motor and average life expectancy based on average RPM speed where too-low might be sub-optimal?
I had an old trusty Nvidia 6600 GT way back when and its fan failed, so maybe I'm over-compensating for getting *burned* (get it?) in the past regarding GPU fans. Not to mention I had a motherboard fan go out on my trusty old ASUS A8N-SLI Deluxe mobo many years ago. That tiny little fan burned its little heart out spinning like mad, oh so tiny...
