I have a Windows Home Server box that I would like to deploy WSUS however it only has 512Mb of memory and from what I can gather performance will be hampered using an internal local SQL database for WSUS. So I thought it would be pretty easy to just install SQL Server Express 05 on my desktop which is running Vista x64 SP1. It installs fine and I have enabled remote connections and forwarded ports should be set right. It is not really a connection problem, I am just confused as to why when WSUS tries to connect to the SQL Server it wants to login as guest.
I have searched for documentation for this and can't find anything to help me.Even MS's site that has the deployment instructions do not mention adding the guest account, I already tried to make my local Users/Guest account a super SQL user and WSUS will connect and establish fine but the instllation fails eventually.
I guess what I am asking, is how do I get my windows home server/WSUS to properly connect to my SQL Server 05 Express? (The network has no domains either)
http://img45.imageshack.us/img45/6292/loginsnt5.jpg
http://img522.imageshack.us/img522/7500/sqlrag7.jpg
http://img135.imageshack.us/img135/2262/wsusme6.jpg
