BonzaiDuck
I'm sort of stymied. I have a perfectly well-functioning WHS v.1 or "2008" based on Server 2003. With less than 43% disk usage, I'm in no hurry to expand it. It's running on a E8400 system and Gigabyte P35 or 45 chipset -- "UDR3." (or something . . . I can find manual or use monitoring software). The C2D Wolfdale was all I had available when I built it.
Now I've repossessed my old P4 Northwood 3.4 Ghz 3GB RAM, with clean XP Pro installed -- in tip-top condition.
If I buy WHS 2011, I would wish to reinstall the WHS v.1 on the Pentium 4. I have a good idea that it will work quite well.
But that means a hardware change, which means a re-activation requirement. How likely would it be for the MS Store or someone to give me a new activation key? How would I contact them?
