Severian
I'm doing a clean install of WHS on a machine that was also a WHS, so I know the hardware is good for WHS. However, after I boot off the DVD drive, and enter my key, WHS spends probably a half hour doing the first part of the GUI setup, then after it does the first reboot, the system just sits there at the "Press any key to boot from DVD" prompt, and never moves on to the next stage of the install. If I change the boot order back to hard drive first, the install also doesn't continue.
I have formatted the hard drive to blank NTFS, so it's not like the WHS install sees an older install on the drive.
I'm using an old P4 2.8 on a Gigabyte 8K1100 mainboard. SATA ports are disabled in case that was an issue. I'm using an IDE DVDRW drive and hard drive. Everything shows up in the BIOS normally detected, and I've tried switching out both the hard drive and the DVD drive, and the exact same issue recurs.
I've installed WHS a few times, and this problem seems to pop up from time to time, for reasons that I can't seem to pin down. I haven't found any answers via Google, so I'd like to know if anyone here has any insight.
thanks
thanks
