- Jan 2, 2003
- 5,916
- 0
- 76
was woundering if its possible to have a WHS run inside a VM?  basically what i'm thinking is I have my HTPC that doubles as my server atm.  was woundering if its possibly to load a VM up on the HTPC that would run WHS.
			You probably can't run Automatic Updates on the host PC. If the Host reboots after Windows Updates, it's the same as turning off the power switch on your virtualized Windows Home Server. Updates on the Host will need to be done manually (after shutting down the virtualized WHS).
You can do that in Hyper-V, but Windows Virtual Server 2005 R2 isn't quite that smart. You can tell the child partition to shut down or "Save State" AFTER the "Virtual Server" service is stopped, but the host OS is likely to be shutdown before the "Save State" or "Shutdown" action can be completed. At least that's what happens on my own virtualized WHS server when it's running under "Virtual Server 2005".Originally posted by: bsobel
You should configure your host to suspend vms at shutdown and start them at system startup, this removes this issue entirely. I let me hyper-v machine patch and all of its vms restore nice and cleanly.
Since the OP wants to run a media center, he/she likely won't be running Hyper-V or ESXi (can't access a TV tuner and other AV hardware). So the virtualization software would likely be MS Virtual Server, VMWare Server, or Virtual Box. MS Virtual PC has had disk size limitations that would handicap WHS.
I see your point, but, that would require using Server 2008 as the "Media Center". Whether that's practical would really depend on what functions the OP wants and if he/she has access to a "reasonably-priced" source of Server 2008. But, yeah, it's certainly possible.Originally posted by: bsobel
By hyper-v I was presuming server 2008 not just the hyper-v server peice, so the tuners should work fine...
Originally posted by: JeffreyLebowski
I would prefer the backup solution to be a seperate machine.
If you're running your WHS in a VM on a machine you want to back up, what do you do when the main machine takes a crap? and the drive with the VM on it is hosed?
Although I have not, admittedly, tried it, I know of no reason why Drive Extender wouldn't work on a virtualized WHS. If you create a new virtual hard drive and "insert it" into the WHS virtual server, then WHS should see a "new" hard drive and offer the option to add it to the WHS machine as another storage drive.Originally posted by: Falloutboy
so reading this it should be possible but without the drive extender?
Actually, I'm kinda' counting on this working, since, at some point, I'll certainly need to add a second hard drive to my (Hyper-V-virtualized) Windows Home Server. I plan to put another physical hard drive into my server, tell Hyper-V to put a Virtual Disk on it, and then add that virtual disk into my virtual WHS server.
Mine's Hyper-V, but my setup is otherwise identical to yours. I'm quite happy with it so far. I run WHS in 512MB of memory and it consumes a tiny amount of CPU time from my Quad CPU.Originally posted by: dclive
I'm running WHS (and a few 2003s) on an 8GB quad 2.4, running ESXi. Works great! I couldn't be happier with it.
