whs hooked up to a tv not working.
alanwest09872
1,100
Ok if I have only the television hooked up to my pc no monitor it will show the bios post and show whs loading but when the logon happens it clicks off.
If I use a monitor and have the television hooked up I try to run nvidia control panel it will not show the television under multi monitors.
I have the most recent bios update and the most recent control panel and nvidia drivers.
The card I am using is 9800gt. it has 3 outputs. 2 dvi and 1 television output.
This is a server pc that I wanna hook up to my hd tv.
So if anyone knows how to get the tv out working I would really appreicate some help. Thanks a ton
KIAman
3,342
23
Most likely it is an incompatible resolution or refresh rate.
Try using your normal monitor, set it for 640x480 and lock 60hz refresh. Then hook it up to your tv.
