Final Configuration Purchased:
CASE: COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/...x?Item=N82E16811119137
$69.99
CPU: AMD Sempron 140 Sargas 2.7GHz Socket AM3 45W Single-Core Processor Model SDX140HBGQBOX - Retail
http://www.newegg.com/Product/...x?Item=N82E16819103698
$37.99
Motherboard: GIGABYTE GA-MA74GM-S2 AM3/AM2+/AM2 AMD 740G Micro ATX AMD Motherboard - Retail
http://www.newegg.com/Product/...x?Item=N82E16813128342
$54.99
RAM: Kingston 2GB 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Desktop Memory Model KVR667D2/2GR - Retail
http://www.newegg.com/Product/...x?Item=N82E16820134632
$29.99
Video Card: Integrated in Motherboard
PSU: CORSAIR CMPSU-400CX 400W ATX12V V2.2 80 PLUS Certified Compatible with Core i7 Power Supply - Retail
http://www.newegg.com/Product/...x?Item=N82E16817139008
$49.99
Hard Drive: 2x SAMSUNG Spinpoint F2EG HD154UI 1.5TB 5400 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
http://www.newegg.com/Product/...x?Item=N82E16822152175
$199.98 (for both combined, not each)
OS: Microsoft Windows Home Server 32 Bit 1 Pack (Power pack 1) - OEM
http://www.newegg.com/Product/...x?Item=N82E16832116550
$94.99
Fan/Heatsink: Stock provided with Retail CPU
CD/DVD: SAMSUNG Black 22X DVD Burner Black SATA Model SH-S223B - OEM
http://www.newegg.com/Product/...x?Item=N82E16827151187
$29.99
Total: $567.91
The Original Thread was as follows:
____________________________________________________________________
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Running Windows Home Server to backup computers on network as well as stream DVD rips to a HTPC.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$500-$700 (U.S.)
3. What country YOU will be buying YOUR parts from.
U.S.A.
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
Intel and nVidia fanboy
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Just the peripherals.
6. IF YOU have searched and/or read similar threads.
Yes
7. IF YOU plan on overclocking or run the system at default speeds.
Default speeds as it is just a server.
8. What resolution YOU plan on gaming with.
No gaming.
9. WHEN do you plan to build it?
ASAP.
Hey guys, I have never built a server before. I think I can handle the install okay, and I know how to put together a computer (done it for many, many gaming rigs). However, I have no idea what goes into selecting the parts for a good server.
I was told performance is not really a big deal, it's all about the hard drive space. I think this is especially true in my case because I will be ripping Blu-Ray DVDs. I then plan on streaming this media to a HTPC.
I have chosen the following components, but am open to completely changing them. Note: I went with kind of a better motherboard than I probably need merely for the extra SATA ports. I chose the coolermaster case because i have one for my gaming rig and I love it but maybe these server rack things are the way to go? I have no experience with these.
$69.99
3x Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drives - OEM
$284.97 (total)
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBPQ - Retail
$54.99
GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard - Retail
$134.99
Intel Pentium E5200 Wolfdale 2.5GHz LGA 775 65W Dual-Core Processor Model BX80571E5200 - Retail
$63.99
$94
CORSAIR CMPSU-400CX 400W ATX12V V2.2 80 PLUS Certified Compatible with Core i7 Power Supply - Retail WITH COMBINATION SAPPHIRE 100253HDMI Radeon HD 4650 512MB 128-bit GDDR2 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Low Profile Video ... - Retail
$94 (for both)
Thank you very much for your time. I can edit with links to the components if that's easier for people.
$69.99
$37.99
$54.99
$29.99
$49.99
$94.99
$29.99
Total: $567.91
$500-$700 (U.S.)
U.S.A.
Yes
No gaming.
ASAP.
$69.99
$284.97 (total)
$54.99
$134.99
$63.99
$94
$94 (for both)
