WHS and Win 7 Major problems
gscone
489
I changed the duplex speed on my wHS and now none of my PC'a cant connect to the WHS server. Can anyone help???
wiretap
642
If you set it to something your router/switch doesn't support, it won't work. Also, other computers on your network should be setup with the same settings to ensure they work together at the same speeds. Sometimes with 'forced' mismatched settings it may not want to connect. I have ran into that problem before.
If you have a gigabit switch, setup your network adapters to auto-configure (assuming they're gigabit as well), they will automatically recognize the proper speed for the switch you're running and it will go smoothly. The slower devices (10/100) will auto-configure to their respective speeds as well.
So.. I'd set it back to auto and give your computers a restart to see if you fix your connection problem.
gscone
489
How do I revert back to undo any changes?
JackMDS
29,563
432
Change it back to auto, and reboot.
Also it is better to give your WHS computer a Static IP out of the DHCP range.
DivideBYZero
24,117
This. It becomes even more important when you use the WHS remote share/access functionality and need to add port forwarding to your router config.
