Who's using the onboard sound on the Epox 8K7A?
MTDEW
4,284
37
Just built a system for my bro, he decided to use the onboard sound until he gets the cash to get a better soundcard later.
Ive never tried the onboard sound on my 8K7A cuz I have a SB Live.
To say the onboard sound was a massive pain in the A** would be a polite understatement!
I tried downloading the latest drivers for the sound chip from the 8K7A section on Epoxs website, weel when I run the .exe file, all I get is a dos box popup with a bunch of jibberish that ends with "installation aborted".
He is Using WinMe, Nvidia 27.42 drivers,DirectX 8.1
What I need to know is.
1)what drivers are you using for onboard sound? Where from?
2)what is listed under sound video & game controller properties for your soundcard? & Driver dates please!
3)What EXACTLY should be enabled in the bios, I have the onboard sound(Ac97) on AUTO, but what about the soundblaster reference,gameport & the mpu 401 reference?
4)What Via 4.1s are you using? (I know to use the AMD miniport & not the via one)
5)Did you install the USB filter from the Epox CD?
We got the sound working with the drivers from the epox cdrom & MOHAA + RTCW sound fine, but in Nascar4, the sounds stutters awfully bad & drops the framerate from 40-50 to 10-12fps when sounds start playing! (spotter sounds like hes underwater & engine sounds are major snap crackle pop!)
So help me get all the right drivers installed, Im using WinXP now, so I havent played with the via 4.1s in awhile.(XP defualt ones work just fine) :)
jcmkk
1,159
That is about all you can expect from AC97. It doesn't really matter what drivers you install because it wont help much. Just try to survive until he can get a better sound card.
MoFunk
4,058
3 things.
1. He's using ME
2. If he is using a 200mhz FSB chip this will be the main problem. I was using onboard sound on my 8k7a with a 1.4 Tbird 266 with NO issues. I could have many things open and still get no MP3 skips. Well I killed my 1.4 and had to use an old 1.2 200 for a while. Sounded like crap!
3. He's using ME
