Whoohoo! My cellphone has low radiation!
gopunk
29,239
lowest 10
all this time i was concerned because i have a habit of putting it in my crotch while i drive :p
it's the motorola v60c btw :)
.42 digital .397 analog
gopunk
29,239
Originally posted by: lnguyen
.99 digital, 1.42 analog for me... now what does this mean exactly?
According to the Cellular Telecommunications Industry Association (CTIA), SAR or specific absorption rate is "a way of measuring the quantity of radiofrequency (RF) energy that is absorbed by the body." For a phone to pass FCC certification, that phone's maximum SAR level must be less than 1.6W/kg (watts per kilogram). The SAR level listed in our chart represents the maximum SAR level with the phone next to the ear, a level obtained through required FCC tests.
minendo
35,560
22
Digital: 1.4597
Analog: .9255
Maybe that explains my decreasing knowledge.
Atrail
4,326
I hope we all dont get brain cancer in 15 or 20 years.
Are the phone manufactures the ones we will be suing or the phone companies?
Or both?
Nokia 6360 0.63 1.15
FoBoT
63,084
15
fobot.com
gimme a break, cell phones don't radiate enough for it to matter
KingNothing
7,141
I use a hands-free set most of the time now, but I have wondered if by leaving the phone clipped to my belt I'm just moving the cancer from my brain to my crotch. I'm not really sure which is worse. :p
Cyberian
9,999
You were just doing that because you had it in 'vibrate' mode.
Peetoeng
1,866
Originally posted by: gopunk
lowest 10
Unless your crotch is actually using the phone conversing with other crotches or honeys, then you should not worry about it. The number you quoted is radiation during conversation not at idle/standby.
Atrail
4,326
They still do emit radiation in standby.
Very tiny amount, but its still there.
KingNothing
7,141
lowest 10
Yeah, but if you're using a hands-free set, then the phone is at your crotch while it's in use. Close enough, anyway. Especially when you use it while driving. Speaking of which, there is a good reason to have it on vibrate at your crotch while driving. If you regularly drive with music cranked up, you might not hear your phone ring. :D
HiTek21
4,391
woah my phone has 0.94 I'm going to mutate into a horrible looking monster soon ROAR!!!!!!
I have the Nokia 8890 btw
toant103
10,514
lowest 10
mine is the most i think.
Panasonic Allure with 1.49
