Whoah, I can feel the current going through the computer's power cord
RESmonkey
4,818
I know a magnetic field surrounds the current in a wire, but why can I feel something moving inside the wire? Feels so wierd.
JohnCU
Banned
Dec 9, 2000
16,528
4
uhmm you shouldn't feel it shaking. it's probably the case shaking and the vibrations making their way through the cord.
although you can feel and it hear it in a transformer. but not a single cable.
JohnCU
Banned
Dec 9, 2000
16,528
4
Originally posted by: RESmonkey
I'm serious, when I hold the wire, it's vibrating and it's humming.
because its connected to a PS that has a fan on it. the fan is causing the PS to vibrate slightly which makes the cable vibrate slightly.
RESmonkey
4,818
More wires, but those wires don't vibrate. The wire goes from PSU to a surgeprotector/outlet.
RESmonkey
4,818
Oh my god, I just felt the cable that goes form my GPU to VGA monitor, and it is shaking the most. It is vibrating 2x the power cord.
RichardE
Banned
Dec 31, 2005
10,246
Stick your tongue on it, tell us if it hurts. (My little brother found out his computer had a short by doing this to his case /facepalm)
RESmonkey
4,818
I understand the power cable vibration. The GPU cable is shaking because of the GPU fan? It's an OC'ed ati 9600, it shouldn't cause much shaking.
Oct 25, 2006
11,036
11
Stick it down your pants. Double if you are a girl
ConstipatedVigilante
7,670
Well, that's definitely not current. Because NO CURRENT GOES THROUGH THAT CABLE. It's just digital/analog signals to the monitor. I bet you're missing something really obvious here...is your CD ROM drive spinning a lot? Hard drive?
RESmonkey
4,818
My comptuer does hum, but only these cables are vibrating. Why shouldn't the network cable vibrate? Or is it that only these two cables vibrate because of their thickness?
JohnCU
Banned
Dec 9, 2000
16,528
4
what the hell do you think a digital/analog signal is? :confused:
