whoa there, mflops=low
rival
3,490
CPU time: 128:54:38
Speed: 2.18 Mflops
Rate: 0.19 % / hour
Efficiency: 365.91 CpF
Estimated total time: 522:35:41
Estimated time left: 393:41:03
Est. time done: 1:47 AM (+16)
Completed: 24.67%
Drift rate: 10.2926 Hz/s
FFT number: 7436
from seti spy...
i used to run at 220MFlops...and only 6hrs per WU, whats the deal?
wintop says seti running at ~67% cpu...
running win98se, amd k7 800mhz, 512mb pc133...
Poof
4,305
Possibly a very low angle range WU. Something less than ~0.3xx. If so, it's a known bug that they refuse to fix. :|
Smoke
Distributed Computing Elite Member
Jan 3, 2001
12,650
207
Shouldn't SETI be running at 97%+?
/Quit using that computer for unimportant things. HA LOL :D
rival
3,490
<< /Quit using that computer for unimportant things. HA LOL >>
yea ill stop when you stop :)
anyhow..
Work unit name: 28ap01aa.16652.18881.292318.157
Recorded: 4/28/01 2:59:21 PM UTC
Position: 0 h 35' 45" RA, +9° 45' 35" Dec, 0.432° AR
Nearest constellation: Pisces (Psc)
Source: Arecibo Radio Observatory
Base frequency: 1.419033203 GHz
ho hum, oh well, 16 days left on this ONE WU :(
mk
3,231
I've had it happen on my comp a couple of times (but also with higher AR WUs).
Usually some other:)Q!!!) application has hogged a lot of CPU time and after quitting it SETI has stuck to a very low usage.
Rebooting has always fixed the problem (at least for me).
medic
Can you give us a list of what's running and their usage according to WinTop ?
Smoke
Jan 3, 2001
12,650
207
I'd kill that sucker and start over. :|
rival
3,490
wu gone, got a new one, 245mflops, 4:30 total time till completion :)
thanks guys/gals/"others" :)
Smoke
Jan 3, 2001
12,650
207
These WUs get distributed over and over so you don't have to worry about any science being lost. When you get something like that...get rid of it and start anew.
Glad you are now looking a reasonable CPU Time. ;) :)
