So after getting some random bluescreens with STOP 0x0000009c MACHINE_CHECK_EXCEPTION (0x00000004, 0x8086EFF0, B2000000, 00070F0F) (yes, the 4 parameters are ALWAYS the same) and searching the internet and doing some investigating on my own, I've tracked my problem to the NVIDIA RAID. Only when I'm doing some fair amount of I/O operations it decides to take a dump. As an example i was installing a game from a ISO i had on the RAID parition right onto the same RAID partition. Yes, not the most optimal way of doing things, but my point is this... every time during the install it would bluescreen. Tried it at least 5 times before I got fed up with it. Moved the ISO elsewhere and installed on my regular 60GB drive... no hitch.
I've also made the problem reproduce itself when i was working on a CD image (using cdimage.exe to combine all the Visual Studio Express editions into one CD). Same thing, a lot of reading and writing to the same drive. Blue screened all the time. Moved everything to another drive (after a few bluescreens trying to get the data off the RAID) and all worked great. Funny thing is When i first got this thing installed i moved 100GB from a backup drive to the RAID with no problem.
So, obviously the problem is the RAID. I have a A64 Venice E3 3200+ and 1GB (2x512MB) Kingston Hyper-X memory all on a EPoX 9NPA+ Ultra. Processor and RAM pass all the tests I can throw at them (Prime95, SuperPI, memtest86, etc). So it is not that problem at all. I have nForce 6.70 installed (no firewall), and my BIOS is the latest one available on the EPoX website. OS: WinXP SP2. System is running @ spec -- NO OVERCLOCK -- of course it WAS OC'd, but i brought everything back down when the problems showed up... and they're still there
Is there some techincal paper that can tell me what the parameters of the STOP error mean? From AMD since its the CPU throwing that error?
Bigger question -- who do I call/email/whatever about my problem to attempt to find a solution..... nVidia, AMD, EPoX? I dont think I'd get much help from anyone, but then again I havent tried yet. Anyone else out there with a similar situation with their computer and has gotten some help?
<edit> OK i remembered something that happened a while back that may have something to do with this problem. When i did move all that data (the 100GB) back onto my RAID from my backup drive it seemed like it was moving really slow, but I didnt check it for a few days after (HL2 was taking FOREVER to load, etc). Ran HDTach -- results were less than stellar. Well the nForce driver had my two drives set on Multi-Word DMA2.... so i cranked em up to UDMA5 and the speeds improved. I'm thinking the speed increase has something to do with this?? While the drives themselves can do UDMA5 (2xWD800BBs) maybe the chipset is detecting errors and letting the CPU know the game is over?
