But these guys must be buying them somewhere else, like a hardware store or a warehouse. I'd like to buy directly, cutting out the middleman 🙂 I'm sure these are like 2 cents each!
Originally posted by: Rhombuss
Any hardware store that sells screws will most likely sell rubber grommets too. Check out places like Home Depot - that's where I bought mine.
I checked out 2 Home Depots. Neither one carried the grommets of the right size. They were all too big. You bought yours online or local? Do you have any part # info? Thanks in advance!
I'm in Toronto, so probably Canadian Home Depots stock different items than US counterparts. Plus...there are tons of hardware surplus stores here and they sell grommets for about 5 cents (CDN) a piece 😉.
Ah, PainMan! Thanks. I will make a trip to my local RadioShack tomorrow.. err, today already. I was very surprised to find out that Home Depot doesn't carry small grommets. Bastards!
You're welcome, and I hope you didn't wander the halls of Home Depot in vain for too long. That place can be frustrating if you're not looking for wood or bathroom fixtures.
The first one also sells extremely cheap cable ties, heat-shrink, connectors, wires and more. They're 10 times cheaper than from those online overclocking stores. Score!!!
P.S. Searching for "washer" instead of "grommet" finds clothes washer and dish washer 😉
