Originally posted by: Paperdoc
Originally posted by: axelfox
I'm also looking to run some more lines to different rooms at my house and this thread is very useful.
If you read the threads and articles from the following links, you'll see that they do not discourage placing the amplifier before the cable modem.
CableTVAmps.com
HTS
DropAmp
In reading these carefully, I noted a few things.
First one is informative. It uses the term "Bidirectional Amplifier" for a unit with an amp and several ouput ports that boosts the downloaded signals in the 54-1000 MHz range, and lets the uploaded signals in the 5-42 MHz range pass back up unimpeded. However, that device does not boost anything in the low freq band. It is what I called a "Passive Return" feature. The site notes that "cheapie amps" do not do this and may cause real problems with cable modems or set-top boxes for "Pay per View" and similar interactive functions.
The second, a forum discussion, refers to a particular Radio Shack product, among others, billed as a "Bidirectional Amplifier" with 4 outputs, each at up to 8 dB boosted from the input. Although it says the uploaded signals ar passed, it does not specify the unit's impact on these signals.
The last, operated by Electroline who makes amps, is more detailed. It offers an 8-port amp with each output boosted 4 dB above input, and specifies that the uploaded "Reverse" signal is reduced by 10.5 dB. That is exactly what you get from 3 levels of 2-way splitters at 3.5 dB each level. The site also recommends specifically for houses with cable modems a different model with "Active Return", and says this one sends the uploaded signal back out with no reduced signal. It appears they have built in (I suspect between the main amp and the splitter network) a bandpass amp of 10 dB gain for the 5-42 MHz range that sends its output around the main amp back up to the cable company. This is ideal for any place that has more than one cable modem. The only issue would be that the 10.5 dB loss in the splitter network happens before the 10 dB offsetting gain, so the final signal has just slightly more noise in it. However, I'm sure that is not important.
By comparison, my suggestion was to put a single 2-way splitter first, taking one output to the cable modem and the other to the simple distribution amp for all other TV's. This way would send back up the line a slightly less noisy signal, but it would be weaker as it leaves the house.
