Who else here has water cooling ??
Soulkeeper
6,740
156
just wondering who is using water cooling here
I have a dangerden II block with 2 120 watt pelts
this thing cools anything I can throw at it
But condensation is definately a problem
what materials/methods do you all use to protect against condensation/moisture ??
thanks
Soulkeeper
6,740
156
i'm thinking about just taking the pelts off and running it above ambient so I won't have to worry bout condensation
I might lose 100 or 200mhz in overclock but ohh well
atleast i'll be able to play UT
also i think my motherboard is screwed it works sometimes and sometimes it don't work every since i drilled a hole in it
