Question White VGA-LED
dAWDLE004
Nothing out of ordinary, the pc was booting up as it always does but right when it was supposed to show my desktop, it showed some type of a grey-black screen and my empty bar, I thought it was just loading but a couple of seconds later it lost connection to the monitor, black screen, fans on full power, I have never in my almost a year since I got it, heard it in such a state. I waited for a while, to see if something will change but I started to get worried that something worse will happen so I chose to close it and start it again after a couple of minutes. Fans were back to working at their normal speed but there wasn't any signal going out to the monitor. I checked the output, I changed the HDMI, I even tried to connect it to different types of mintors or TVs, no signal. I would have also liked to check if the monitor has an issue but earlier this morning, apparently, my other laptop, broke down as well earlier today, suspiciously in a similar way, after a couple of seconds of being powered up, showing lights and everything, a grey screen appeared and it supposedly closed itself.
My graphics card is being powered, its leds are working, a GIGABYTE GeForce GTX 1660 SUPER Gaming OC 6GB, but it doesn't output anything and obviously, the VGA-LED is white and is lit ( I checked the manual and it doesn't tell me much more other than the fact that the GPU, PCIE, M.2 device is not detected or fail).
I am not very experienced with computers and I'm scared to do anything that might harm it but I don't understand what happened. Is there any way I can fix it myself because I don't understand what happened out of nowhere, it just makes no sense.
fans on full power
You probably do not have a monitor issue.
Fans on full power is a CPU hard crash. They default to full power when that happens.
So if I understand correctly, you now have two dead computers that failed in the exact same way?
Did your neighborhood have a power surge? Do you have a surge protector? Lightening storm? Using the same ethernet switch? What was common between both computers? Did they have the same peripherals plugged into them? Printer? Monitor? powered USB hub?
