Originally posted by: Keego
It was on the inside, looked like grease from bacon or something, kind of foamy, kind of greasy, it was yellowish-white. Any ideas what it is?
Originally posted by: Evadman
How did your oil look? If it looks like ( forgive the term ) Baby sh!t then your head gasket is gone and is allowing water to mix with the oil.
Originally posted by: 911paramedic
Teflon grease? That is white/yellow. Pretty common on bolts or things you do not want to seize.
Originally posted by: etech
Frequent short trips can do that also. The car doesn't get hot enough to burn the water out of the oil.
The ventilation of the crankcase should also be checked. A sticking PCV valve will keep the moisture trapped in the crankcase.
Originally posted by: The_good_guy
did your car overheat recently ona long idle.
well you have blown a gasket, most likely the head gasket..
check your coolant cause your burning that.. top it off and then fix your car up.
The white stuff is your coolant in oil, you got some major work on your car due.
by the way what car is it?
