I can't imagine anybody posting streams of random white noise -- and if you loop a short run of random noise then it's not random and your mind will hear the looking. In the meantime, just make your own.
Tune a radio to a frequency with no station, or do the same with a TV.
Put the TV on with the volume down low on one of the God channels or something else completely banal and boring so it will not distract you into watching. I used to simply watch TV and study because silence or even white noise drives me crazy.
I would play some music, but don't loop it. If you need true "white noise", tune a radio to a station with nothing broadcasting, or disconnect your antenna/cable from the TV and turn it on. This only works, though, if your TV is old or lousy, and doesn't mute the sound when it's not getting a signal.
Originally posted by: fire400
...wasn't that a movie!?
