White LED Kit
RavenSEAL
8,661
I'm thinking about snatching one of these for my case with a windowed side-panel. While my whole rig is pretty much AMD, but I feel like red is too much of a cliche.
I'm looking at the NZXT kits, what's the consensus on these?
tulx
257
I used four individual LED's for my case. Two red and two white. The video card area is lit red, which is fitting, since those are AMD cards, and the CPU-motherboard is lit "white". Works pretty well, although I should have used more white LED's - they are not as visible as the red ones.
I used http://www.scan.co.uk/products/phobya-83064-two-5mm-ultra-bright-red-leds-on-30cm-cable and http://www.scan.co.uk/products/phobya-83062-twin-5mm-ultra-bright-white-leds
I recommend you take into account that the white one will not be as apparent as the red ones - you will have to use more of them.
