I had whistler and ME installed on seperate partitions, and used ntloader to boot into the appropriate OS. Last week i decided to go back to 98, so i reformatted C: (ME\98 part) and reinstalled. I knew it would wipe over my mbr, but since i had been able to manually repair the same type of situation on a 2K\98 machine in the past, i thought i'd skip it. doh.
When i boot with the whislter cd, i get the option to install, repair thru recovery console, and exit. When i choose recovery console, i login as admin, and execute
FIXBOOT
FIXMBR
After post, i get "cant find Ntloader".. I was under the impression those two options above did just that, can anyone help me so that i'll get the ntloader option menu without reinstalling? Also, how do i make the ERD's in whistler if i didnt do it upon install?
keep in mind i :
1.dont have ERD's
2.have access to the full directory structure of the whistler install via the 98 WinExplorer.
Thanks for the help.
FIXBOOT
FIXMBR
keep in mind i :
1.dont have ERD's
