I have one, and so do 1.8 million others, maybe some here will need this info...
They are made by Whirlpool but also rebadged as KitchenAid and Kenmore
Whirlpool is recalling 1.8 million of these microwave oven range hoods (over the range units, not countertop) They want you to unplug them immedietly and do not use them, 7 fires have been reported so far. Check your micro for serial numbers that begin XC...... the serial number is right inside the micro when you open the door.
I called yesterday 1-800-785-8897, they will mail out the info to get a service call which can take 6-8 weeks. Sooo in the meanwhile, they are sending a voucher for up to $100.00 to buy yourself a microwave to use in the interim. They said the voucher should arrive within a week. BTW They asked me if I had another microwave to use, which I do not.
here's some linkage
CPSC.gov
Whirlpool
here's some linkage
CPSC.gov
Whirlpool
