Well then you are just sucking in the heat of them anyway. By blowing into the heatsink you will move more air across the heatsink. What cools your body surface tempature more, a fan blowing on you or a fan sucking air from you? If you have good air flow into the case you should not have to worry about a video cards heating the air inside the case.
