Which wall mount?
Solotak
10
I think i've finally decide what 30" lcd i'm getting that's in my area, and that's the HP lp3065. So i went hunting for a lcd wall mount that meets the simple demands of: swivel vertically up and down, swivel horizontal left to right, tilt up/down, AND depth (bringing it closer to you or further away from you). I really am surprised that i have not found one wall mount that can achieve this. It is imperative that i have all these functions but i'm having a hard time finding one. Can someone point me to the right direction cause if there really isn't any wall mount like this then there's no point of me getting this lcd.
Thanks
lavaheadache
6,893
14
I' ve got an "cantilever" omnimount that does anything you could want it to do.. check it out at circuit city. it's a $300 mount but I picked it up on ebay for $75
linky
Solotak
10
Looks good but it doesn't seem to sway vertically up/down. That's the most important feature i need.
lavaheadache
6,893
14
up and down??? i think you asking a little much from your tv. May I kindly ask where you plan to mount this. That mount can tilt the screen up and down but you want to move it say a foot or 2 higher or lower at random? Maybe you would be more wise to just look for someone to hire and hold your tv for you
Solotak
10
I have turntables that connect to serato (cueing software to play mp3s on vinyl). I need to raise the lcd to eye level when i'm standing up when djing. But when i'm using the pc i need to have it lowered and brought out closer to me and tilted because my chair is leveled at a low keyboard position.
Originally posted by: JACKDRUID
http://www.beachaudio.com/Chief/Fwb-110b-p-60391.html
but i would personally get one of those robitc ones if i have the money...
http://www.800stereo.com/k2mo40to60un.html
I know i'm being picky but that height doesn't seem to go at a 90 degree angle up or down. So even if it was pushed back the furthest it can go and i raise the height, the monitor will be about 20cm from my face, not a good thing for a 30" screen. Maybe it's possible to just use those arm things that sit on the desk but screw it on the wall. That would work wouldn't it?
