Which TV Tuner/Capture card.
Jaxx89
14
Hi folks.
Here is my Computer Config.
Intel Core i7 920
Gigabyte GA-EX58-UD5
Corsair 6GB @1333
Sunbeamtech CCF 120
XFX Nvidia GTX260
Hauppauge WinTV PVR 150
Seagate HDD 1TB + 1.5TB*2
Vista 64 Bit
What I need to know is which internal TV Tuner/Capture card should I go in for as the Hauppauge WinTV PVR 150 doesnt work well above 4gb of RAM. So to use it I need to limit my RAM to under 4GB.
The quality is pretty good for both viewing and capturing. But I don't want to use the work around or reduce my RAM.
Please suggest me a good internal TV Tuner/Capture card which will work with my PC config and allow good capture.
