- Apr 2, 2001
- 5,661
- 5
- 81
Yeah, yeah, I've searched.
I have a feeling I'll eventually want a beefier heatsink for my P4 when it arrives, despite the claims of how well the stock cooler does the job. I'm considering these based on others recommendations and reviews:
Zalman CNPS7000-Cu / CNPS7000A-Cu (what's the difference?)
Thermalright SP94
Swiftech MCX478-V
I'd be using a Panaflo M1a on the latter 2 heatsinks, which according to SVC, runs @ 30db, 2450 rpm. The Zalman runs @ 25, 2400 rpm. Is Zalman fudging their numbers or are they really that much quieter than the Panaflo? I can't find published CFM numbers on the Zalman fan, but would estimate 45-50.
I'd have this fan hooked to the fan control on my Musketeer, which I use frequently to turn the fan down @ idle, so a heatsink that performs well with a small amount of airflow is important. I hear that the Thermalright heatsinks don't really shine unless they're being pumped full of air. How true is this?
Cost isn't a big issue and neither is the convenience/inconvenience of installing the heatsink, but performance is. I'm willing to pay for a heatsink that fits my needs. From the looks of it, the Swiftech would give me the most flexibility in fans (should I need a higher flow fan, like an H1a, in the summer) and provide good cooling when using a low flowing fan. I just don't see many reviews of it, espeically those with low flowing fans.
Thermalright SP94
Swiftech MCX478-V
