Which tire rotation direction?
Kristi2k
1,364
4
I have Defender T+H - Size: 225/65R17 tires and am trying to determine if they are directional tires? I need to rotated them and want to know which pattern to use.
Update in post #10. Here's the copy & paste:
Front wheel drive. I would like to know though, what is proper for these tires.
2012 Honda CRV: Michelin Defender T+H - Size: 225/65R17
2009 Honda Fit: Michelin Premier a/s - Size: 185/55R16
I've had the shop do the rotations but I want to do them myself now.
jlee
48,518
223
Do they have an arrow with a "Rotation" label on the outside sidewall?
skyking
22,678
5,800
Those look like OEM tires and from what I could see online, they were not directional.
Use the cross pattern right front to left rear etc.
Scarpozzi
26,391
1,780
You can usually tell directional tires by looking at the tread pattern.
Directional tires have an asymmetrical pattern designed to throw water to the outside and those tires usually have water channels.
Kristi2k
1,364
4
It looks like the shops did the criss cross pattern. These are not factory tires though, just an FYI,
