ok so here are the two options i have:
1. CoolerMaster IC Essential E2 Thermal Compound
http://nextworld.in/product.aspx?sku=HW8569
2. CoolerMaster IceFusion Thermal Compound
http://nextworld.in/product.aspx?sku=HW6954
what is the difference between the two? especially the icefusion one is non-curing compund. what does it mean?
my needs are:
1. to apply thermal compound in between my cpu and my hyper 212 plus.
2. to use the same thermal compound, if possible, in my graphic cards because it's been more than 1 and half years since they've been running so i'm guessing it's time i reapply some of it.
which one of the two options will be better?
and i know none of these may be better than arctic silver 5 but then again that product is not readily available in my region. i mean i'll take the pains to find it only if it's really REALLY worth it.
like it's going to make a difference of 10c-15c from what i'm getting right now in readings
my needs are:
