which temps to trust???
absolom
my temps show up on asus probe as 39C at idle, on motherboard moniter, my temps show up as 39C at idle, however, in my bios, temps show up as 50C idle, which temps should i trust??? my motherboard is an asus a7n8x del. rev. 1005 and i'm running a amd 3000 at 200 x 11.5 with 1.775 vcore
what temps are right???
doubtful.. the bios probably gives you the internal diode reading with the a7n8x, whereas asus probe is giving you teh socket-thermistor temp.
Now, if you go to MBM's website, you should find a way to enalbe diode reading with MBM5 and your mb for windows.
Mike
the bios is giving you the diode temp while the asus probe is giving the socket temp. so the diode is the correct temp to watch. NForcersHQ Search here for a special module for MBM5 that is specialy made for A7N8X'S GL.
