Hi guys,
I'm planning on building a new PC, but can't decide what speakers to get.
I'm currently on some Creative Labs 5.1 5300s, which are decent enough for now, but for my new PC, I want something better.
I'm on a budget, so I wanna try to keep it as low as possible, but I still want good quality.
I mostly play games, and listen to mp3s, but I do occasionally watch movies etc... on my PC, and I may hook them up to my XBox aswell.
Here's my choices :-
Klipsch ProMedia 5.1 (These are real expensive, so I only want to get them if they're the only ones worth getting.)
Cambridge Soundworks/Creative Labs Megaworks 510D (Expensive, but cheaper than the Klipsch speaker, and is full 5.1 Surround Sound.)
Cambridge Soundworks/Creative Labs Inspire 5.1 5700 (Not expensive, but are they any good?)
Can you please respond with the order in which you would go for, if you were on a bugdet.
Put simply - What's the best price : sound ratio - Are the 5700s any good?
I've heard of some problems with the 510Ds, but are they any good?
Have you got one of these sets, and how would you rate them?
Have you heard all 3, and which is the best in your opinion?
Thanks people.
- Sliquid
Thanks people.
- Sliquid
